EOS 77D Card Error
Patrick7701
My Canon 77d  started to display "Er 02" card cannot be accessed.
I have tried many new card and all other ways it has been resolved, kindly help me out.
2 REPLIES 2
Please confirm the cards you are using are full size and not micro with adapter?
You said you've tried several.
Next, please reset your camera to default settings.  Now remove any accessories and the lens.  Insert the card and power on.  Open the menu and see if you can format the card?
If you cannot, remove the card and inspect the card slot for dust, dirt or bent contacts.
If the above does not help, your body will require service.
You can try Canon or midwestcamera dot com.
You have tried other cards without a satisfactory result.
ebiggs1
First try formatting the SD card in a Windows computer (not a Mac) and see if that makes a difference. Always use full sized SD cards, never, never micro-SD.
EOS 1DX and many lenses.
