04-05-2020 03:34 PM
There is no utility software for the modern OSX. Is there some sort of workaround for this? Like a universal OSX Utility that works on most macs?
And when will the Utility software for the "new" OSX drop?
04-05-2020 07:40 PM
@Kimsellstedt wrote:When I search under EOS 70D there is no Utilities program there because of the OS being unsupported (Catalina). When I go into the more general support and download I can't see any sort of program more than image software and RAW support.
Have I missed something on the site or is ther regular Utility program with the live view simply not for Mac users?
its in the eos utitity choose a older osx and d/l and install.
you have to put the camera in live veuw first i have a 70D but i use windows 10
04-05-2020 03:52 PM
What tasks do you need to perform? If it's to transfer your images, does your Mac have an SD card slot? Or, connect your camera via its USB cable and use Apple's Image Capture software. Or if you have Adobe products, Lightroom is one application that can also import photos.
Technical details about software: There is no true universal software. Software companies need to ensure they move with the times. In the old days, software was written for 68K Macs. You could then create hybrid 68K/PowerPC applications. But that changed when Apple moved to Intel. Then you could create hybrid PowerPC/Intel software. Years later it became hybrid 32-bit/64-bit. And now, it's 64-bit only. In short, complex. And no doubt this will continue to evolve over the years to come.
04-05-2020 03:55 PM
A card reader is your best option until until a updated EOS Utility is relesed for "Modern OSX". Catalina currently.
04-05-2020 03:56 PM
Ok, but how do I get the software? I have a card reader for my mac but no software.
04-05-2020 04:48 PM
@Kimsellstedt wrote:Ok, but how do I get the software? I have a card reader for my mac but no software.
its built in the os just like reading a thumb drive. you just have to take the extra step to direact the files to the correct folder.
also after you trasfer the files and want to reformat the card make shure you format the now backed up data card in camara not via mac your using
04-05-2020 05:15 PM
Ahh, I need the Utility software for the live view not to transfer photos. There I have no problems.
04-05-2020 07:01 PM - edited 04-05-2020 07:46 PM
@Kimsellstedt wrote:Ahh, I need the Utility software for the live view not to transfer photos. There I have no problems.
Your camera may not be supported under Catalina. Give Canon a call at 1-800-OK-CANON.
04-05-2020 07:13 PM
04-05-2020 07:40 PM
