02-03-2024
10:12 AM
10:14 AM
My 700d and my wifes g3x have both had unwanted image quality changes. Both set on L and changed to various levels without us going into the menu screen. Anyone else had this?
02-04-2024 03:25 AM
I have worked out what happened. Hit Q button instead of button above it when doing backlit compensation then turned wheel and that altered image quality setting.
02-03-2024 10:53 AM
I’m not understanding what you mean by the cameras are set to L. Do you mean M?
02-03-2024 01:55 PM
You need to reset both cameras back to defaults settings.
02-04-2024 03:25 AM
02-04-2024 09:40 AM - edited 02-04-2024 09:40 AM
Glad you found the problem. It would be good if you could mark your reply as a solution. This will help other users know that this issue has been solved. And that may also help other users in the future.
02-04-2024 10:18 AM
Will do. Sorry,new to site
