EOS 700D & PowerShot G3 X Unwanted changes in image quality
Sandwichken
My 700d and my wifes g3x have both had unwanted image quality changes. Both set on L and changed to various levels without us going into the menu screen. Anyone else had this?
Sandwichken
I have worked out what happened. Hit Q button instead of button above it when doing backlit compensation then turned wheel and that altered image quality setting.
5 REPLIES 5
Waddizzle
I’m not understanding what you mean by the cameras are set to L. Do you mean M?
ebiggs1
You need to reset both cameras back to defaults settings.
EOS 1DX and many lenses.
Sandwichken
Glad you found the problem. It would be good if you could mark your reply as a solution. This will help other users know that this issue has been solved. And that may also help other users in the future.
Ricky
Will do. Sorry,new to site
