05-06-2014 07:02 AM
05-02-2016 04:20 PM
@PhotosByNeva wrote:
There is a "safe remove" for usb on Windows 7. The little arrow in bottom right of your home screen. Click that, there should be several icons that show up, onee is the little usb one. Click on that. It is only there ifnyou have a usb port in use. I use it all the time.
The simplest solution is to first turn off the camera. One second later, Windows tells you that the device has disconnected.
05-13-2016 12:20 PM
