EOS 60D Display not working
cbaquiran
I was upgrading my firmware and something happen while I'm upgrading, now my display don't work in creative mode but works on movie mode. I think the firmware got corrupted, is there a way to fix the firmware. thank you.
6 REPLIES 6
Tiffany
Moderator
Moderator
Welcome to the Canon forum!
So that the Community can help you better, we will need to know the model camera you are using.  Any other details you'd like to give will only help the Community better understand your issue.  If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
deebatman316
What camera are you using first of all.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
i was using canon eos 60d
Sorry, i forgot to mention canon eos 60d that's my camera i was using.
Can you access the menu in video mode. To reset the camera and custom functions back to factory default.
-Demetrius
You don't have many options.  Its unlikely your camera can be serviced by Canon due to its age. (13yrs)
(Longshot) If you remove the card and lens from the camera, does it power on and do the displays work normally?
If not, and the camera means a lot to you contact midwestcamera dot com.
Regrettably, I don't believe it can be recovered with your intervention.
