EOS 5D Mark IV error since firmware upgrade: "Invalid correction data for digital lens optimizer"
LorraineMc
I am hoping someone can help with this error message. I've been scouring the internet and the "solutions" to remove the battery and replace, remove the sd card and replace, reset to factory, redo the upgrade all result in no improvement. I am using a Canon 5DIV and this is the message: Invalid correction data for digital lens optimizer. use EOS utility to replace the correction data.
Using a MacBook Pro on Sonoma 14.5. I don't know if that matters because the message is on the camera, not the computer.
I then found the EOS Utility, downloaded and ran that too, but to no avail.
I've tried different lenses, different SD cards, and even just the camera body without a lens on it, just to see if the message still comes up. Also tried cleaning the connectors.
I am getting photos that are okay, but heavily vignetted, but I'm able to fix that in Lightroom.
I've gone into settings and tried both turning on the digital optimizer and turning it off, but absolutely nothing gets rid of this message.
This is only since I upgraded the firmware to 1.4.0 using: 5D400140.FIR. Is there a way to downgrade it back?
I did find another forum topic about this, but that solution didn't work. Does anyone have a solution that will work? I really don't want to send this to Canon...
Thanks in advance!
4 REPLIES 4
March411
The best solution when it comes to firmware failures or issues is to contact Canon directly.
800-385-2155 or 800-652-2666
Marc
Windy City
To find common ground you must be willing to search for it.
Our interests intersect more than they diverge.
R5 Mk II ~ R6 Mk III ~ R7
Lenses: RF Trinity and others
Personal Gallery
Yeah, I was trying to avoid sending the camera off to Canon. Takes weeks to get back (in Canada), and expensive. Hoping to find a solution first. Do you know if it's possible to downgrade?
March411
They may be able to assist you without sending it to them, it's worth giving them a call to check.
I had a similar issue with my 90D and they walked me through a reload that resolved my issue. Just hit tech support and not CS.
Marc
Windy City
Personal Gallery
I'll give them a call. Thanks.
