09-08-2016
04:24 PM
10:44 AM
As some of you may know, there is a software fault in the 6D that causes the GPS to remain on when the camera is powered down, causing rapid battery drain. Yes, the GPS can be turned off via the menus, but that shouldn't be necessary. Do you happen to know whether the 5D Mark IV has this same bug, or if the GPS turns of with the camera? Thanks!
05-20-2023 11:50 AM - edited 05-20-2023 11:51 AM
I strongly suggest that you start a new thread for YOUR issue, instead of hijacking an existing thread that is several years old.
Have a nice day!
