EOS 5D Mark III Producing Corrupted Images
Cailinnua
I have a Canon 5D Mark iii camera which keeps producing corrupted images as attachedUntitled.pngUntitled.png. There is no pattern to these images being produced, I am using the same lens and settings and might take 200 images with 3 corrupt and 30 with 10 corrupt. I have attached a sample of images being produced. Sometimes they have these colour blocks, sometimes less or more of the photo is covered, and sometimes black
10 REPLIES 10
Tronhard
VIP
VIP
Hi Calin and welcome to the forum:
Just before this began to happen, has anything changed?  For example any settings, different cards etc.
The first things I would suggest are the least invasive:
1.  Do full camera reset to default settings:  If you want to save your current configuration, save it to one of the C1-C2 custom settings.
2. Try different cards.  You may have a corrupt card
cheers, TREVOR
Hi Thank you for your reply, I have tried a number of different cards, I haven't reset will try that now
Do you see the corrupt images in live view why using the rear LCD Screen. If so your image sensor maybe is on its way out.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
If this is the issue can the image sensor be replaced?
Did you do a reset on the camera yet?  It may solve your issue for no cost.
cheers, TREVOR
I was under the impression that OP had reset the camera to factory . Since they mentioned the use of other memory cards.
-Demetrius
-Demetrius
I did ask and they have not confirmed that and they responded that it was something they would try when I suggested this. "Hi Thank you for your reply, I have tried a number of different cards, I haven't reset will try that now"
cheers, TREVOR
Are you using both card slots? If your using both cards with the camera set to "record to both cards" the corrupted images would be on both cards.
-Demetrius
-Demetrius
I'm trying to figure out how to reset the camera sorry for delay
