10-19-2022
12:51 PM
10:22 AM
I have a Canon 5D Mark iii camera which keeps producing corrupted images as attached. There is no pattern to these images being produced, I am using the same lens and settings and might take 200 images with 3 corrupt and 30 with 10 corrupt. I have attached a sample of images being produced. Sometimes they have these colour blocks, sometimes less or more of the photo is covered, and sometimes black
10-19-2022 12:58 PM
Hi Calin and welcome to the forum:
Just before this began to happen, has anything changed? For example any settings, different cards etc.
The first things I would suggest are the least invasive:
1. Do full camera reset to default settings: If you want to save your current configuration, save it to one of the C1-C2 custom settings.
2. Try different cards. You may have a corrupt card
10-19-2022 03:42 PM
Hi Thank you for your reply, I have tried a number of different cards, I haven't reset will try that now
10-19-2022 05:00 PM
Do you see the corrupt images in live view why using the rear LCD Screen. If so your image sensor maybe is on its way out.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
10-19-2022 05:45 PM
If this is the issue can the image sensor be replaced?
10-19-2022 05:46 PM
Did you do a reset on the camera yet? It may solve your issue for no cost.
10-19-2022 05:56 PM
I was under the impression that OP had reset the camera to factory . Since they mentioned the use of other memory cards.
-Demetrius
10-19-2022 05:57 PM
I did ask and they have not confirmed that and they responded that it was something they would try when I suggested this. "Hi Thank you for your reply, I have tried a number of different cards, I haven't reset will try that now"
10-19-2022 06:04 PM
Are you using both card slots? If your using both cards with the camera set to "record to both cards" the corrupted images would be on both cards.
-Demetrius
10-19-2022 06:44 PM
I'm trying to figure out how to reset the camera sorry for delay
