EOS 4000d black screen but camera shoots. help!
rigelkitty
Hi everyone,
I've just acquired an EOS 4000d from someone who used it only sparingly (allegedly). The first time, I was able to take a few shots, and everything looked ok; today, the LCD screen went black again and never came back. Right before that, I was trying to zoom in on a flower bud. I was unhappy with the automatic mode and switched to manual, and that's when the blackout happened.
Actually, when I switch between modes, the screen flashes for a moment with the usual text, but it goes black immediately.
The camera sounds like it autofocuses with each mode I select, and it appears to shoots photos and save them to the SD. I've tried a lot of things that I've read about:
-removed SD card and battery
-put a new battery in
-cleaned all contacts
-removed the rubber cup on the viewfinder (and it looks like this model has no proximity sensor anyway)
Does anyone have another idea? Is there some hard reset button hidden somewhere that would allow me at least to reset everything to factory defaults?
Thanks in advance!
29 REPLIES 29
rigelkitty
Ah I wasn't saying it's weird because there are no physical signs of damage.
What I mean is: the screen shows some text for a split second when I turn the dial to switch between modes. It just flashes and goes blank again. If I press DISP or MENU it stays blank.
The screen also works when in video mode. It shows stuff. Image and text. But if I press menu, nothing happens.
So the LCD bit does work. It is not broken. Something else is the matter. A connection of a software issue, I dunno.
" I bought it on ebay. Tested it immediately, and it worked fine. Put it back in its box until the next day, in my room. Took it out again to try a few more shots,..."
OK it sounds like you did this recently and not much time has passed.  You most likely have eBay warranty and can either return it or get your money back as it is obviously broken and you did nothing wrong or abusive to it. Did the seller say it was in good working condition? It is not so it needs to go back or refunded.
If you decide, I would not, to go the repair route as Stephen suggested, make sure you get an estimate first.  The repair can quickly overcome the retail value of a 4 year old 4000D.
EOS 1DX and many lenses.
rigelkitty
Yeah he says he used it very sparingly and it always worked fine. It did work when I first tried it, to be honest. It feels super weird that it should die on me just the next day, though, but I also feel bad for the seller if he is telling the truth. Perhaps it was mishandled during transport.
I'll talk to Ebay first and see what the options are.
Thanks!
BTW, about FW updates...........
"A professional photographer suggested that I do that after I showed her the camera, so I trusted her..."
Not taking anything away from this working pro and this photographer may be a wiz bang photographer but she knows little about the mechanics of a camera. My great niece has a very successful career as a photographer but when it comes to the camera internals she is clueless. Like most people I suppose.
When I was working full time I used CPS for service and repairs. Most of the time a FW update goes fine but if it doesn't you can brick a fully functioning camera and only Canon can undo and fix it then. Most of the time the FW just adds a language or small fix to a bug. Sometimes a lens is added, that kinda stuff. You must know if the FW update affects what you do otherwise it isn't needed.
"It feels super weird that it should die on me just the next day,..."
You know the old saying, "Anything made by the hand of man can and will fail." Every seller takes some responsibility to make sure you get the item in reasonable working order.  You did not. Don't feel bad because this is in them. Now if you have had the camera for months or even weeks and used it, it is on you but not at this point. eBay has a very liberal guarantee designed just in cases like this.
"I'll talk to Ebay first and see what the options are."
This is a good idea because I am not an Ebay expert but I have used them for a few items.
amarildo
Any chance you fixed it? I am experiencing almost the same issue
Hi there! I have this same issue. Did you find out what tge problem was please?
MBTC88
Hi there, did you ever find out the issue please? Thanks.
pspanhel
Hi, did anyone find a fix for this issue?  I have just acquired a 3000D (same as 4000D) with the same issue. The display works when no SD card inserted - it has the message "No Card", but no button works, cannot access any menus.  With an SD card inserted, the display is blank, and momentarily displays current mode as you switch between modes.  When a lens is attached AF operates only when switching between modes momentarily.  Taking a photo works and stores it on the SD card but nothing on the display.  This model does not have the proximity sensor to blank the display.  I have looked internally and there is no sign of water ingress and all connections are fine, the camera looks new.  Cannot connect to PC via USB, it is possible that wifi is enabled, but cannot tell.
After writing the post above, I went back to try something else out on the 3000D, and in Movie Mode, the screen displays correctly, but no buttons work again, then after pressing several buttons including the shutter, the camera came to life, working again, I disabled wifi to ensure I could get USB to connect if it fails again.  The firmware is at 1.1.0 which is the latest, so not a firmware issue.  I turned it off then on again and the display was blank once more.  Tried the same sequence of movie mode and buttons and nothing worked.  Then after pressing the shutter button repeatedly, the camera came to life again, the display is normal. Then on half-pressing the shutter I realised that the display is blanked when the shutter is half pressed and the buttons are disabled.  The problem is in the shutter release button, something is causing it to be recognised as half pressed when it is not, I will check the shutter button tomorrow, but it may need replacing?  At least I have found the source of the fault now.
