07-10-2021 11:44 AM
Hi everyone,
I've just acquired an EOS 4000d from someone who used it only sparingly (allegedly). The first time, I was able to take a few shots, and everything looked ok; today, the LCD screen went black again and never came back. Right before that, I was trying to zoom in on a flower bud. I was unhappy with the automatic mode and switched to manual, and that's when the blackout happened.
Actually, when I switch between modes, the screen flashes for a moment with the usual text, but it goes black immediately.
The camera sounds like it autofocuses with each mode I select, and it appears to shoots photos and save them to the SD. I've tried a lot of things that I've read about:
-removed SD card and battery
-put a new battery in
-cleaned all contacts
-removed the rubber cup on the viewfinder (and it looks like this model has no proximity sensor anyway)
Does anyone have another idea? Is there some hard reset button hidden somewhere that would allow me at least to reset everything to factory defaults?
Thanks in advance!
07-11-2021 07:11 AM
Purpose is to blackout LCD when camera is placed to eye.
07-11-2021 10:08 AM
"Purpose is to blackout LCD when camera is placed to eye."
I think we understand that. I just don't remember it on any of my XTi's. Could be. At any rate it doesn't seem to be the problem either there or not in this case.
07-11-2021 10:03 PM
@ebiggs1 wrote:"Purpose is to blackout LCD when camera is placed to eye."
You're right, Ernie. It wasn't a feature on the XTi or XSi, but it was on the T4i and I think they abandoned it on other rebels. At least, it wasn't on the T6s or T7i, But, it's a moot point, for this thread. However, it is a feature on the R6, go figure 🙂
Newton
07-12-2021 06:21 AM
So, a quick update.
I've managed to connect the camera to my pc, all I can do is download the photos, but I can't write on to the SD (I've downloaded the firmware update file and I'm supposed to copy it to the root folder but.. nada).
The EOS utility software freezes when I try to update the firmware from there. It displays "busy" then dies.
Also, the lens moves by itself like it's trying to focus on something. Even in P mode and with the cap on.
It feels like a software issue. Anyone? Is it toast?
07-12-2021 09:46 AM
"(I've downloaded the firmware update file and I'm supposed to copy it to the root folder but.. nada)."
It is always a bad idea to try and update FW on a misbehaving camera. Its good that it didn't take. Most likely, if possible, it can only make things worse. I don't think you are going to fix it. Sorry.
07-12-2021 10:02 AM
Hi, rigelkitty!
Not a tech, but I used to be one in a past life.
Put the camera in "P" mode on the main dial. Push the <Menu> button. Does a menu display, or is the LCD screen still blank?
If the LCD screen is still blank, the camera requires repair. If you're in the USA, You can start the process HERE. Outside of the USA, you'll need to reach out to Canon in your country. You'll find options HERE.
If you see a menu, go to the third yellow wrench menu and then down to the "Clear Settings" option, and then to "Clear all camera settings," then arrow over to "OK."
Once you've done that, go down to "Clear all Custom Func. (C.Fn.)" and hit "OK" again.
This will reset your camera back to defaults.
You'll see this on page 192 of the full manual HERE.
I hope this helps!
07-12-2021 10:08 AM
A professional photographer suggested that I do that after I showed her the camera, so I trusted her... but thanks, I'll keep that in mind in the future!
07-12-2021 10:12 AM
Hi Stephen, thanks for the suggestions!
No, I can't see anything at all on the LCD, except in video making mode -- and even there, pressing any button has no effect. I can't access the menu in any way. The LCD also flashes when I turn the dial, but returns blank immediately. That's what's weird, the screen is not physically broken, evidently.
I'll talk to Canon support and see if anything can be done.
Thank you 🙂
07-12-2021 10:19 AM
"That's what's weird, the screen is not physically broken, evidently."
Its electronic. It doesn't have to show signs of damage to be broken. Did you drop the camera? Did you get it wet even just a little? Leave it in a hot car, etc? Many things can cause electronic failures.
07-12-2021 10:44 AM
