11-26-2022
01:32 PM
03:58 PM
Will my canon 250D work with studio lights, my old camera which is a 4000D didn’t work because of a missing contact in the hotshoe. The hotshoes on the cameras look the same so i’m not sure if this camera will work or not. If it doesn’t is there anything i can do?
11-26-2022 02:37 PM
Hi zoethomson The Rebel SL3/ EOS 250D will not work with your studio lights. The camera lacks the center contact on the hot shoe. The only flash units you can use are Canon's speedlites.
-Demetrius
EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM & EF 70-200mm F/2.8L IS III USM
EOS 40D & 5D Mark IV
430EX III-RT & 600EX II-RT
11-26-2022 02:50 PM
Thank you! Do you know if there is any other cameras that don’t have the centre contact, just so I can avoid buying another one that doesn’t work 🙂
11-26-2022 03:02 PM
The Rebel T7i/ EOS 2000D, Rebel SL3/ EOS 250D, Rebel T7/ EOS 800D, Rebel T100/ 3000D/4000D. The Rebel T8i/ EOS 850D DOES include the center contact.
-Demetrius
11-26-2022 03:07 PM
great, thank you
11-26-2022 03:19 PM
What specific features do you need in the camera a mid range camera may better suit your needs. When it comes to strobes or external flash units an entry level camera you may be quite limited. I would look into a mid range body ie EOS 90D.
-Demetrius
11-26-2022 03:21 PM
Actually, a Godox V860 series with TTL has version made for Canon SL3. Also a TTL flash extender/repeater will work…. With high performance features— so you’re not stuck with Speedlite as your only option.
11-26-2022 03:27 PM
great, thanks for getting back to me!
11-26-2022 03:49 PM
I would verify compatibility just because a 3rd party item says it "compatible". Doesn't necessary mean it will be 100% compatible especially with different cameras. Or even the same camera with older or newer firmware installed on them.
-Demetrius
11-26-2022 04:05 PM
will do, thanks for all your help 🙂
