06-15-2021 02:43 PM
I have an EOS R6, and shoot in Raw and JPG. I had been saving both file types to the same card, and everything works as expected. I would like Raw to go to card 1 and JPG to card 2, but when I do so, the EOS Utility changes the name of the JPG file (coming from card 2) to append a "_1" at the end of the filename. Because of this, I see two images in Lightroom (which would only show a single image if they were the same name).
Is there a way to prevent the EOS Utility from appending "_1" to the filename for files coming out of Card2?
I have seen recommendations on other boards to remove Card2 when importing to fix the issue when the camera is set up to duplicate images to the two cards, but in my workflow I would like to still import the JPG file from Card2 that matches the Raw file from Card1.
When saving both two one card w/ Standard
Setting - Wrench Icon, "Record fundc+card/folder sel.", Camera "Rec options" set to "Standard"
Computer file name after importing via EOS Utility - R6_1234.CR3 and R6_1234.JPG
When saving Raw on one card, and JPG on second card
Setting - Wrench Icon, "Record fundc+card/folder sel.", Camera "Rec options" set to "Rec. separately"
On camera file names (card 1) - R6_1234.CR3
Computer file name after importing via EOS Utility - R6_1234.CR3 and R6_1234_1.JPG
When saving both on one card, plus backup on second card
Setting - Wrench Icon, "Record fundc+card/folder sel.", Camera "Rec options" set to "Rec. to muptiple"
Computer file name after importing via EOS Utility - R6_1234.CR3 and R6_1234.JPG, R6_1234_1.CR3 and R6_1234_1.JPG
06-15-2021 03:01 PM
06-15-2021 03:12 PM
I'll give that a shot. I like how the EOS Utility creates a dated sub-directory, but I think I did read that LR does the same. I'll experiment today.
06-15-2021 03:13 PM
06-15-2021 03:23 PM
John - Thank you!
I tried LR, and it fixed the issue. Both files have the same filename (without the _1). This helps my workflow overall as imports were the only thing I used EOSU for.
06-15-2021 03:38 PM
John - The _1 is apended by EOSU, not LR. My old workflow was [redundantly] to have EOSU copy files from the camera to Windows10 file manager, then go into lightroom and update the catelog for any new photos. You can see the photo names on each of the cards, and then post-import names from both EOSU and LR below.
I really appreciate the help. This was driving me nuts, and I know I'm far from the only one who wants to separate Raw and JPG on different cards. I spent a couple hours searching, but could not find the right keywords to get to this answer.
06-15-2021 03:50 PM
Thanks for posting that. Looks like a potential EOSU bug. It should recognize the file type and not consider it the same file.
Depending on what you want the JPEGs for, there is a setting in Lr to treat JPEGs next to RAW as the same or different files. The same setting will hide the JPEGs.
