04-10-2021 02:12 PM
I have found being able to set "Release Priority" very useful with lenses that do not focus very quickly and/or with subjects that are difficult to auto focus on while tracking. I would rather 6-8 focused frames/sec than 10-12 unfocused frames/sec.
So, why does it seem like Canon removed this setting from EOS R bodies? This is from the R5. You can set it release priority for One Shot AF mode, just like you can in the high end DSLRs. Unlike the high end DSLRs, there is no menu selection to set 1st or 2nd Image Priority when shooting in AI Servo AF mode.
Does R5 automatically set Release Priority to focus or speed? What good is up to 20 frames/sec if they are not focused?
04-17-2021 07:03 PM
04-18-2021 12:13 AM - edited 04-18-2021 12:20 AM
@DigitalByDesign wrote:
You will never have 20 fps no matter what you do as that frame rate is under theoretically perfect conditions, not real world use. That's the honest answer I've found from honest reviewers.
I understand that, Sherlock. The question is how do you compensate for it? Canon has seemingly removed the setting to compensate for it. What say you?
04-18-2021 10:48 AM
Waddizzle, that does seem like an oversight and hopefully they will update it in firmware. Maybe once Canon's mirrorless line matures they will hit their stride again. I have used focus priority going back to my 2004 era 1D Mark II body.
I bias the settings in my 1DX and 5DS bodies to focus, not release, because I have no use for poorly focused images. The only time I might change the setting would be if I were capturing images to help an athlete with skills training where release speed would be most important but for that I use a camcorder which is better suited than a stills camera.
Rodger
