05-31-2014 11:31 AM - edited 06-01-2014 03:33 PM
Rebel EOS T3i message; Card cannot be accessed. Reinsert/Change the card or format card w/camera. Reinsert, same message. Turned of/on reinsert, same message. Changed card, works. I need info on recovery or how to save data on the original card (DANE-ELEC Pro 200x 8GB SDHC Class10.) Thanks P.S. I have not formatted the card.
05-31-2014 02:06 PM
Hopefully you haven't reformatted the card, if so, I fear all is lost. If not, use a third party SD card recovery app. There are a ton out there. I can't recommend any because I've never had to recover a card (knock on wood), but I know Sandisk makes one that is suppose to work, and Photorec is another that comes up frequently.
05-31-2014 05:02 PM
Almost any HDD data recovery software will also work, even if you formatted the card. The card is just an external drive as far as your computer is concerned.
05-31-2014 08:43 PM
This one got a good review at another forum I belong to.
http://www.transcend-info.com/Support/Software-4
06-04-2014 08:40 AM
"Hopefully you haven't reformatted the card, if so, I fear all is lost." This simply is not true, the data can be recovered using
software on the internet. Even if card is formatted all he data is there just in a different order. The software can read it and all data retrieved.
06-04-2014 11:37 AM
@cuda719 wrote:"Hopefully you haven't reformatted the card, if so, I fear all is lost." This simply is not true, the data can be recovered using
My mistake, I didn't realize that. I assumed the camera would wipe everything clean with a reformat.
08-11-2014 10:26 PM
Next time, no matter what happens, just do not format this camera memory card with useful information.
But, right now, to rescue your card data after formatting process, stop adding new files on this card and apply some card data recovery software to take chances, like 4Card Recovery, Recuva, PhotoRec and iCare Data Recovery Free, etc.
No matter which one you prefer to use, always make card data backups well in the future in case of any similar data loss problems.
