Dark line through pictures...EOS 70D
AZmateo
I read another thread where the diagnosis was a hair on the sensor... Could this be the same problem???...
3 REPLIES 3
Ray-uk
Whiz
Yes, it certainly looks like a hair, if it changes position on each shot then it may be a hair stuck in the shutter blades. It is not a fault with the sensor.
If you remove the lens, switch the camera to "manual clean" then you may be able to blow it out with a rocket blower or even pick it out with a pair of plastic tweezers, do not use canned air and try not to touch the surface of the sensor assembly. If not confident then take it to a camera dealer to get it cleaned.
AZmateo
Ok thank you I'll report back and let you know what happens. I appreciate your quick response.
ebiggs1
When you look through the VF you see it?  It is not on the photo?
EOS 1DX and many lenses.
