11-11-2018 02:34 PM
I have a Canon EOS Rebel. Recently when I'm taking pictures gold, green & red hexagon shapes show up randomly in the pictures. Can anyone help to let me know how to fix this? Thanks.
11-11-2018 03:13 PM - edited 11-11-2018 03:15 PM
That sounds like lens flare...
Does it look like the object in the lower portion of this image?
If so, it's usually just a matter of shading your lens with a lens hood. If one didn't come with your lens, a matching hood is available to purchase separately. Just search by your lens designation or look it up at the Canon website. Be careful, though... because different versions of lenses might use different hoods.
The above was a test done with my EF-S 10-22mm lens when I first got it. The matched lens hood for it is very large and I was hoping to use the lens without it. I thought that might be possible, since the 10-22mm lens is unusually resistant to flare. However I decided to carry the lens hood with me and use it (like I do with all my lenses), after seeing the difference it made (below)...
Flare problems also can be caused or amplified by cheap "protection" filters that people put on their lenses. If you have a filter on the lens, try again without it.
Alan Myers
San Jose, Calif., USA
GEAR: 5DII, 7DII (x2), 7D(x2) some other cameras, various lenses & accessories
FLICKR & ZENFOLIO
11-11-2018 03:29 PM
At low focal ratios, a point of light will blur in the shape of your camera lens aperture blades. E.g. if you have a 6-blade aperture, then the opening would be in the shape of a hexagon. Some camera lenses have enough aperture blades and round the edges enough that they create a near circular shape.
An out-of-focus traffic signal would likely look like a green, yellow, or red hexagon (depending on which light was illuminated at the time ... since traffic lights hopefully don't have all lights on at the same time or chaos would ensue.)
A lot of people really take advantage of this with strings of holiday lights. A focused subject in the foreground with something that has holiday lights in the background, will typically result in this effect.
There are even people who go so far as to create "designer" aperture shapes. E.g. take a black card, cut a small shape out of it (say... a heart-shape) and put that in front of your lens. When you take a photo, the out-of-focus points of light will blur into that heart-shape.
11-11-2018 09:09 PM
Yes, kind of although they are usually a more defined hexagon in green, gold, red (some are large, some are small) and on one pictures it could have multiple colors and sizes, some are overlapping etc. I was trying to paste an example but it won't accept the picture.
11-12-2018 01:06 AM
You may need to reduce the image size to post it. I typically reduce images so they are about 1000 pixels on the longest edge. Another option is to post it to an online gallery and provide a link.
11-12-2018 05:37 AM
@Sharonind1279 wrote:Yes, kind of although they are usually a more defined hexagon in green, gold, red (some are large, some are small) and on one pictures it could have multiple colors and sizes, some are overlapping etc. I was trying to paste an example but it won't accept the picture.
Post a sample photo.
11-12-2018 08:11 AM
11-12-2018 08:13 AM
11-12-2018 09:49 AM - edited 11-13-2018 11:47 AM
Yep, those are definitely lens flare.
You might be able to reduce it by...
1. If you don't already have it, get and use the correct hood for your lens.
2. If you have any filters on the lens, remove them.
3. If you must use a filter for some purpose (such as ploarization), be sure it's high quality, multi-coated,...But still only use filters when they serve a purpose. Added layers of glass give more surfaces for flare to reflect..
4. Watch for flare occuring in your viewfinder and slightly reposition yourself and/or the camera & lens to reduce it.
5. Generally be aware of the position of the sun and try to avoid shooting directly at it. In other words, keep the sun behind you as best you can (in both your examples, shooting at a different time of day would have solved the problem).
6. Any strong light source that's directly striking the glass elements of a lens can cause flare effects. It's not limited to the sun alone.
As Tim noted, some people actually incorporate various types of lens flare deliberately in their images. In fact, there are image editing software that ADD flare to images.
A different lens might be less prone to flare... But all lenses do it to some degree or another. Below were shot with very high quality Canon EF 24-70mm f/2.8L lens (with it's lens hood and without any filter). To reduce the flare in the second image, the only difference was was moving camera and lens slightly. It was easy to see in advance in the viewfinder,, what the difference would be in the images.
11-12-2018 10:35 AM
Thanks to the 2 responders for all your suggestions. I will get a lens hood and follow your instructions.
