08-29-2022 12:38 PM
I have formatted my card, put the firmware update on the card(I've tried both SD and CFExpress), set the camera to "P" and I'm still getting "Memory card containing firmware update is required to update" message. I have even tried older updates to try to bridge the gap. I am trying to update from 1.3.1 to 1.6.0 and I would LOVE any help. I am on MacOS monterey 12.5.1
01-18-2024 08:27 PM
I had my off brand battery grip installed and one off brand battery. Removing the battery grip that is off-brand might help. Was the problem that the battery grip was installed or that it was an off-brand, or was it that there was an off brand battery. But for sure with the grip removed and using an authentic Canon battery the version 1.90 firmware installed with an SD memory card with a fresh low level format with the camera, loaded in slot 2 loaded with the .fir file in the root directory. Would it install with also a CF card installed? Would it have installed without a fresh low-level format? I do not know. Just stick with the known good and try it again.
