02-28-2021 06:08 AM
02-28-2021 10:54 AM - edited 02-28-2021 11:08 AM
Current FW is v1.6.0 as of today.
If there was a problem with v1.6.0 we would have heard about it by now. It was released Nov. of 2020.
Your issue is likely related to one of the following:
-Incomplete FW flash
-Corrupt Camera settings
-Faulty lens, 3rd party adapter
-SD card - incorrect formatting, incompatible card
-Network related issue with your environment, wireless router or mobile device
-Malfunctiuoning hardware (camera)
Questions for you:
Was the camera new or used?
What is the brand / model of the SD card you are using?
Is the card full size?
Have you tested with another card or no card installed?
Is the behavior the same?
What lens are you using?
Have you tested with another lens or with no lens attached to the camera?
Are you using an adapter ring?
Canon brand or other?
Troubleshooting:
-Reset the camera's settings in "M" mode
-Pick a FW version and stick with it (just 1)
-I would suggest reflashing the FW. Card should be formatted in the camera. .FIR file should be put on the root directory of the card.
What are you trying to connect the camera to?
Wireless router?
Mobile device?
Does the camera freeze when you try to make the connection or simply when wireless and bluetooth are enabled?
Provide more specific information about the behavior.
~R5 C (1.0.7.1) ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, +RF 1.4x TC, +Canon Control Ring, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve ~Windows11 Pro ~ImageClass MF644Cdw/MF656Cdw ~Pixel 8
~CarePaks Are Worth It
02-28-2021 11:13 AM
02-28-2021 11:24 AM - edited 02-28-2021 11:27 AM
You've done the recommended checks:
Behavior exists across multiple FW's
Reset camera
Tried with different, and no card installed.
No lens installed
Behavior occurs when either wireless feature is enabled and camera restarts on its own
One last thought... the battery? (slim chance this has anything to do with it)
Doesn't sound promising. I recommend you send it to Canon for inspection.
02-28-2021 11:18 AM
04-20-2021 09:34 PM
My RP just started doing the exact same issue.
04-21-2021 01:36 PM
02-28-2021 12:20 PM
03-01-2021 09:42 AM
Use another one. I would hope you have more than one. All mirrorless camera with EVF use a lot of battery power.
The last thing you'd want is being out somewhere with a dead or non-functioning battery.
04-08-2021 05:32 PM
