Canon eos 750d magnification function (+)
mikeshome
Hi, I'm Mike from Australia.  I have a 750d eos canon camera.  I just tried the magnification function (+) which worked well but when I took the shot ithe pic reverted to normal size...can you magnify a shot and then save it?
thanks
Mike
2 ACCEPTED SOLUTIONS
jrhoffman75
No.  The magnifying feature is for evaluating images that have already been captured on the card.
If you were in LiveView it’s still just the image on the LCD that’s enlarged.
As John noted there is no "digital zoom" on this better quality DSLR such as you will find on a lot of lower end cameras, you will need a quality "zoom" lens (or use your feet to zoom) to do this AND the high quality end result is the reason for this optical rather than digital zoom approach.  You can enlarge the image via cropping later but the quality will be lower than if the lens and camera position were used to fill as much of the frame (and the sensor area) as possible when taking the image.  The proper lens for the combination of distance and desired subject matter lets you capture the best image.
Once you capture the image you can only lose, not add, useful original data.  Your 750D requires a different technique to get the desired image compared to simpler cameras but when you use the right technique the resulting image will easily exceed the quality provided by the simpler camera.  The time you spend learning how to best utilize your new camera will pay huge dividends with the results achieved and most new DSLR users will never approach the capability limits of their camera but those who put in the time and effort will be pleased that they did.
Rodger
6 REPLIES 6
jrhoffman75
Rodger
ebiggs1
What you see in the wiewfinder is what your shot will look like.
EOS 1DX and many lenses.
thanks John
many thanks Roger...
thank you...
