10-09-2019 04:36 AM
10-10-2019 04:17 PM
Hello Boss1996,
There are some things that we would like to check.
First, in the Wi-Fi settings
1. Go to Settings> Wi-Fi on the device and touch the little blue "i" in a circle next to the camera's SSID (which should show connected, but may not).
2. Choose "Forget This Network".
3. Then, start from the beginning to re-establish a Wi-Fi connection between the device and the camera.
The second part we would like to check is below.
At times, the Canon Camera Connect application may behave incorrectly when attempting to connect an device to a camera via Wi-Fi. Deleting the app's saved state in the background can oftentimes correct this. This does not harm the app or the device and simply causes the app to launch with a default "state", which can eliminate many issues that prevent the app from connecting to the camera and performing correctly.
To delete the saved state for Canon Camera Connect, do one of the following:
Delete the app's saved state by double-clicking the home button, scroll through the saved states of the apps and find the Canon Camera Connect app, then swipe it up to delete it.
Re-launch the app.
NOTE: If the Canon Camera Connect app is not performing properly or the camera does not remain connected when attempting to connect with Canon Camera Connect, always attempt to delete the saved state of the app BEFORE uninstalling and re-installing the app and before doing a hard re-boot of the device. This should be troubleshooting step #1 when troubleshooting Canon Camera Connect.
We also recommended ensuring that your iOS device is updated to the latest version.
11-01-2019 02:58 AM
11-01-2019 08:36 AM
Hi there Boss1996,
Just so I know exactly where the program is getting stuck, can you please let me know what both the camera's LCD screen and the text on the app say when you are not able to go further?
11-10-2019 08:05 PM
