04-21-2024 04:53 PM
The LCD screen on my Canon T6i is upside down. Any fix for this? I have reset to factory settings and cleaned the sensors. Any help is appreciated.
04-22-2024 04:39 AM
I guess you mean that the image displayed on the LCD screen is upside-down. (It's not likely that the screen is actually upside-down.)
Sp why would this be? Well, when you rotate the screen, the camera flips the image so that it still looks rightside-up to you. This will happen, for example, when you swivel the display out and rotate it into selfie mode. But the point at which the image flips can be pretty close to vertical. So, make sure that your display is completely vertical, i.e. on the click-stop.
If this still doesn't work, then it could be that the sensor inside the hinge which senses the display angle is broken. In that case, your camera will need repair. Whether it's worth it or not on a camera that old is up to you.
04-22-2024 08:26 AM
Yes, the image is upside down. I flipped it to take a picture down low and when I flipped it back, it didn’t adjust back to the proper orientation.
