04-06-2015 12:39 AM
When in Av mode, it doesn't matter what my f-stop is, the shutter speed is really slow and my picture is all white. Manual and Tv mode work just fine. This is a new problem. Has anyone else experienced this? I was hoping for some feedback before I take it into the shop for troubleshooting. I'm currently just shooting in manual, but when other people use my camera, they seem to take better pictures when I set it in Av for them.
04-06-2015 07:59 AM
Make sure you're using the right metering mode. If, for example, you were using spot metering and the middle of the frame was unusually dark, you could get the effect you describe.
Another way to cause it is to use fill flash with Av under very bright conditions. The camera will refuse to select a shutter speed faster than the sync speed, even if the result will be gross overexposure. (Discovered that one the hard way; the XTi manual didn't warn about it.)
04-06-2015 08:58 PM
04-08-2015 09:29 AM
04-08-2015 10:17 AM
So I am to assume P, Auto, M and Tv work? But Av does't? That sure sounds like a setting error somewhere! Another possiblity is your lens is faulty. Try a different lens.
