08-15-2020 11:10 PM
I have a SL3 and I want to purchase an on camera flash. I've read that canon has removed the center pin from the SL3 so it does not work with third party flash. I want to know what the cheapest flash I can buy is that is compatible with the SL3.
Also I was looking into the Canon Speedlite 470EX-AI and wanted to know if its compatible with the SL3. Anyone with the SL3 have you run into the same issue and what solutions did you try?
08-16-2020 01:12 AM
Yes, the 470EX-AI is fully compatible with the EOS Rebel SL3, and the auto-intelligent bounce on that flash is also compatible with your camera.
08-16-2020 12:10 AM
Any current Canon flash will be compatible.
08-16-2020 12:11 AM
08-16-2020 01:12 AM
