Canon SL2 Microphone - External
ajredaelli
I have a brand new SL2. I am trying to setup an external lapel microphone. When I do that, my screen shows three ahlf circles, theicon of a mic, and the word "off" next to it. I cannot seem to get to microphone settings. What am I doing wrong?
Thanks!
17 REPLIES 17
I was thinking that, if you have a mono mic, you could be shorting one side, maybe both if you don't push it all the way in.
Right - that may be it. I will try and find an adapter and give it  try. I know for a fact it was pushed all the way in .... believe me, I tried! 🙂
Just to share, I found a TRSS to TRS adaptor and that did the trick - bottom line is - the original 3.5 mm (TRSS) had three small rings (4 poles) while the TRS only has two rings (3 poles). Once I used the 3 poles (TRS) the issue was resolved. I hope I got that right 🙂
Thanks all for the good advice!
And thanks for reporting back with that information. Not everybody will take the time to do that. Robot Frustrated
My pleasure. Hopefully it will help someone in the future.
parimiti_ds
initially external microphone worked but now it stopped and giving the same error as u had
nickdura
I also had this same issue. From what I have found that does not mean the mic isn't working. It means the wind filter is turned off. I hope that's true and I am still getting decent audio. I will do a test tonight with the mic plugged in and pulled out. But almost positive that's what that symbol means. It has appeared to me in all most whether + or manual or any creative modes. Try setting wind filter to on and see if the symbol still sticks around.
Mbrein1
Hi there,
I have the sound settings set to manual and I am still having a problem Recording any sound whether the external mic is on or off the camera.  Still have a mic with three rings in the word off showing on the screen (in Manuel mode)  when the external mic is plugged in.  I am using the LOTURE external mic On my Canon EOS SL2.
