Canon SL1/100D/Kiss X7 NO POWER
100Dizzle
Had my favorite camera fail on me.
Currently wont power, upon battery entry the red light blinks once.
Note:
1. Have used non Canon batteries and battery grip
2. Tried the most basic trouble shooting as far as I know (Leaving camera open, fresh battery, newly formatted SD)
3. Replaced the entire middle frame/housing of the camera because thought the microswitch may have been damaged. Still same issue. (Probably should’ve used a multimeter when I did this)
7 REPLIES 7
deebatman316
Have you tried using 1st Party Canon batteries.
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
Yes, I meant to mention that. So upon battery contact, the camera flashes red once. Every time.
Will the camera powerup with the lens and SD Card removed.
-Demetrius
Tried that, done it again with leaving it open overnight. Still hasn't turned on. No mechanical noise from the camera upon turning on. Link blinks once when battery is inserted, and beyond that nothing seems to be functioning.
It's time to send the camera to Canon for repair.
-Demetrius
Hi, everyone!  To save you all some time, the EOS Rebel SL1 is an older model which we have retired and as such, we no longer accept it for repairs.
You can also speak with a Canon Upgrade Program specialist to help you score a modern replacement that would meet your current needs at a discount. You can reach them weekdays and Saturdays at 1-866-443-8002.
Hope this helps!
ebiggs1
You did two of the of the most problematic things you can do. Who knows what could be wrong now? If I remember correctly, the Rebel SL1 was not designed to use a battery grip. That in itself tells you it is probably not a good idea to try and circumvent what Canon did not want.
At this point this is about all you can do. Repair is unlikely.
EOS 1DX and many lenses.
