Canon Rebel lens mm to digital equivalent
t3ijbp
So as I had stated earlier, I had just gotten a new Rebel T6.  I like it so far.
I have an old S3 that still works great.  Now i'm looking to expand my T6 to a higher zoom.
Currently my S3 has a lens that is 6.0 - 72.0 mm.
My Rebel T6 came with an 18 - 55 mm lens.
Question is, what does the 18 - 55 translate to for digital?  I want to avoid getting a lens that does not go beyond what my S3 can zoom to.  For example, would a 55 - 250 mm lens surpass the S3 lens?
TIA!!!
5 REPLIES 5
Waddizzle
TIA!!!
The 35mm equivalent range of focal lengths for your "old S3" is 36-432mm, which works out to be a x6.0 crop factor.  Your T6 has a x1.6 crop factor, which means a 55-250mm lens will give you 35mm equivalent zoom focal range of 88-400mm. The 18-55mm lens has a 35mm equivlanet zomm focal range of 29-88mm.
Using a 300mm focal length on your T6 would have a 35mm equivalent focal length of 480mm.  The EF-S 55-250mm lenses are a pretty good match for your T6.  Canon sells a couple of different models, differing mainly by their release dates and the type of autofocusing motors.  The latest and greatest have "STM" at the end of the model number.
I would recommend staying away from the budget priced 70-300mm lenses.  The 55-250mm lenses offer better image quality, and less chromatic distortion.
Does that include the new nano-usm 70-300? Remember, for APS-C you only need to use the inner portion anyway, where chromatic distortion is less.
"I would recommend staying away from the budget priced 70-300mm lenses."
Is the new nano-USM 70-300mm budget priced?
Just above is what the EF 70-300 IS III EF 75-300 III looks like at 200%.  Notice the purple fringing along the high contrast edges.
There is no 70-300 IS III. There is a 75-300 III.
Note, no IS and the different focal length.
Right, you are.  Thanks for sorting that out.  It's the 75-300mm kit lenses that I was thinking about.
