01-02-2019 10:30 PM
Hello,
I have a Canon Rebel T6i with a 18-55mm lens. I am having trouble taking pictures through the viewfinder there is a flashes 15" at the bottom left side of the viewfinder. What does that mean? It takes pictures through the twisty screen just not the viewfinder. I have tried removing the sd card, battery & lens. Not of that has worked.
Please let me know what you think!
Thanks!!
01-03-2019 12:18 PM
The lens cap wasn't on but I was testing the camera out in my bedroom which is very dark at times. Yes, I can see through the viewfinder it just won't take a picture through it.
01-03-2019 12:38 PM - edited 01-03-2019 12:39 PM
Go out on a sunny day and shoot in green square mode. How does that work?
It should take a picture even with a bad exposure. Does it focus through the viewfinder?
01-03-2019 07:53 PM
I went out today and tried to take some pictures, I was able to take as many pictures I wanted through the monitor but once I switched over to the viewfinder I was only able to take one picture and then the whole camera froze. Also in daylight, the 15 changed to a 30.
At approx. 5:00 at night (w/ no daylight) I tried to take a picture through the viewfinder in my kitchen and it was blurry nothing would focus. However, the monitor was able to focus and I was able to take pictures.
01-04-2019 09:36 AM
Did you do this first?
"Did you go in the menus under tools and do clear all settings? That is a reset to factory. There may be some custom settings that need to be reset also. Consult your manual about resetting the camera."
If you didn't, you learned nothing. If you did the camera/lens is broken and needs service. Simple? If you did not do the reset properly you didn't reset the camera completely.
01-04-2019 09:42 AM
Yes. I did reset the camera (to the default factory setting) following directions from some youtube videos. Thank-you for your help. I will look into it getting it serviced.
01-04-2019 10:21 AM
Sorry! ![]()
