02-20-2022 08:49 PM
Hi Canon,
After installing firmware 1.5, I was having my R5 freeze regularly with animal eye autofocus mapped to back button focus. I installed firmware update 1.5.1 this weekend hoping it will fix the issue. I went out today to shooting some shore birds. My R5 locked up 3 times in a period of 1.5 hours of shooting, one of the three was was with error E70. In all three cases, turning the camera off/on fixed the issue; this is different from firmware 1.5 freezes, where I had to take out the battery to fix the freeze.
Please let me know if you need more information about the camera settings. I happy to share them.
Regards, Mo
04-14-2022 10:04 PM
I've installed 1.5.2. I have had no freezes since the install. However, I have not tried it with my 1.4x extender. It is performing so well with both of my main lenses, the 100-500 and the RF 100-400 that I don't want to try it because of so many problems in the past. I'm happy with the way the camera is working now.
04-14-2022 10:06 PM - edited 04-14-2022 10:08 PM
Hi Paul, and thanks for responding. Hmm. This is really odd. I have a one R5 and two R6 units that I use with the 24-105, 24-240 and 100-500 lenses. I use back-button (single-point) focusing and exposure lock. I have the custom setting as: C1 High-speed, Animal Eye tracking, servo; C2: High speed, Human Eye tracking, servo, and C3: Slow speed, tracking no bias, servo. Otherwise, Av is single shot, single point AF, non-servo. I have updated all lens FW to current versions.
Do you still live in NZ?
04-14-2022 10:09 PM
Glad to see that your issue seems to be resolved. I don't use an extender, so I can't comment on the risk of going with that.
04-27-2022 05:36 PM
My R5 locks up constantly with
different memory cards & no memory cards
different lens
different AF modes
servo & single shot AF
I sent it in to Canon repair, they said it passed their tests so there was no issue with the camera. I found that to be a fairly provocative statement and pointed out that the fact they did not find an issue is not the same as there being no issue - it was not a friendly interaction. It ended with them telling me to send it back if it happened again.
The camera/adapter system clearly has an issue. and it seems that Canon repair is not equipped to root cause the issue. This is an issue for Canon engineering to figure out. So what’s the point in sending it back to Canon repair?
I’m kind of at a loss for next step and quite frustrated. My camera is almost unusable whereas my $4,000+ was 100% functional.
I’m not particularly hopeful that this will be resolved in a FW update. I know of no reason to assume this is not a HW defect.
04-27-2022 05:58 PM
I forgot to add - I am on FW 1.5.2
FW update did not resolve my freezing problems. It may actually have gotten worse.
04-27-2022 10:47 PM
No Trevor
Shifted across the pond to Australia 11years ago
04-27-2022 11:05 PM
Ah, you're part of NZ's secret plan to take over Australia! 😁
I am at a loss. My cameras have behaved very well through all updates... I wonder if there is some batch issue that those of you with these problems have in common - not that it would be easy to find out, or for that to cause any further investigation.
04-27-2022 11:07 PM
A friend of mine had a similar issue, we found it that the lens was sometimes not mounting perfectly - leaving what must have been a tiny mis-alignment of the lens contacts: I would have thought that unlikely, but it seems to have been the issue. They unmounted the lens and then firmly engaged the lens... and it worked!
05-17-2022 06:07 PM
Well, I was thrilled. After installing 1.5.2 my R5 was working beautifully. I stopped thinking about freezes. Then today, I was using the 100-500 and photographing a beautiful Osprey that just caught a fish and what happens, FREEZE!!! Then the camera froze again 2 more times within 30 minutes. I was so disappointed. The problem is not fixed. I had to remove the battery to get the camera to start again as I had done in the past. I guess once you have one of these problem cameras it is what it is. Very disappointed. I had taken thousands of photos since the update and really thought all was well. I was wrong.
07-01-2022 07:44 PM
Signed up here just to post that I got my very first R5 + RF 100-500mm freeze today. I've had both body and lens since the days they were released and have used them almost daily. Never had a freeze with them until I went to turn on my R5, and the EVF was black. Tried looking through it a second time and checking that the camera was indeed on, and it was still black. Turned off the camera, but the shutter curtain closing(?) clicking sound didn't happen like it normally does, and the top LCD still showed my shooting settings, even though the power switch was on OFF (I took a picture that shows that). Only after I removed the battery and reinstalled it, did the R5 start working again. Of course, the shot I was going for was a one-time opportunity, and I missed it. I've also had very sporadic Err 60 errors in the past with my R5 + RF 70-200 2.8, but I think both issues are unrelated. I've been on firmware 1.5.2 since the day it came out, as well as the latest RF 100-500 firmware.
