08-29-2021 02:01 AM
08-29-2021 10:14 AM
08-29-2021 03:49 AM
What type of focusing problems? No autofocus? Soft Images?
Are you using a Canon adapter? Are you experiences "focusing problems" with your Canon lens(es)?
You might have a perfect storm of camera settings. Try resetting the camera back to factory defaults.
08-29-2021 10:14 AM
Have you contacted Sigma? You might need a lens firmware update.
08-29-2021 03:24 PM
First of all, the most detail you can give about what lenses are impacted (Sigma alone or native Canon EF as well - it was not clear to me).
Then, exactly what happens when these problems occur?
Did they ever work with the Canon R5?
Are the adapters native Canon ones or third-party?
Have you changed any settings from default in your R5 body - if so, I suggest returning the camera back to factory default and trying the lenses again
Do you still have a EF body and if so do the lenses behave correctly on it?
FWIW, I have the R6, which should be much the same and use Sigma 150-600c and 60-600s lenses without issues.
09-05-2021 05:31 AM
09-05-2021 05:34 AM
09-05-2021 03:17 PM
My suggetion would be to try to confirm the source.
If you can try the lens on another body and see if that continues to be an issue it will tell you if the fault is with the lens
If not, then logic would suggest their is an issue with the adapter or camera
If you test the camera and adapter combination with another lens it should help you include or eliminate that. I would think it unlikely that the camera body itself is at fault - it sounds more like an optics issue to me, but it deserves some further investigation.
In either case you will need to assure yourself that the camera centre line is exactly perpendicular to the plane of the test subject.
cheers: Trevor
09-05-2021 03:19 PM
Maybe the camera needs to be in crop mode. I believe the Sigma 18-35mm is designed for APS-C bodies. I would doubt if the Sigma lens is automatically recognized as an EF-S mount lens, which would cause the camera to enter crop mode automatically.
09-05-2021 03:30 PM
09-05-2021 06:09 PM
@Tronhard wrote:
Do the images show significant vignetting? If so, it would make me suspect that the sensor is not auto cropping the image from 45MP to 17MP and is capturing an angle of view the lens was never meant to deliver.
If you check your manual on P143 and 900 it addresses these issues. You can confirm that the camera is working in crop mode, and, if not, set it as such - then re-test.
I am not aware of any third party manufacturers that use the actual EF-S mount, when having the EF mount works just as well on all Canon bodies. So, I would not expect the camera to automatically switch to a 1.6 crop.
