01-18-2025 05:42 PM
I have inadverdently set all 6 settings in Register/recall. QUESTION How do you delete/erase or change these settings I have searched and can not find an answer.
01-19-2025 07:44 AM
You can re-use a registered setting and simply register it again to re-use it with different AF settings. Alternatively if you choose a setting then remove all the check marks from the left column does that render the preset effectively unused?
https://cam.start.canon/en/C018/manual/html/UG-04_AF-Drive_0100.html#AF-Drive_0100_4-1
Last ditch method is to rest the camera using the individual settings and choose the AF option
https://cam.start.canon/en/C018/manual/html/UG-07_Set-up_0280.html
