03-23-2017 01:08 AM
I bought a Canon Macro EF-S 60mm 1:2.8 lens for my T5i camera,
when I focus a object, no matter in MF or AF, it is clear in the window, when I take it, the picture is blur,
I took too many times and make sure my hands are stable, but still doesn't work, how can I do it?
thanks,
Mark
03-23-2017 11:08 AM
Can you post an example?
Does the focus confirmation light come on and beep?
What other lenses do you have and do they work?
Mine has worked fine on 3 or 4 bodies by now.
03-24-2017 10:34 AM
"Can you post an example?"
Please!
03-26-2017 12:54 PM
There is sound from lens druing focusing and the smal window changed to green and a beep from the camera when it is focusing. When I press button to take picture, the picture is not as clear as it shows in the camera window. But occasionally, I get a clear picture, maybe 10% chance.
Please see images.
03-26-2017 01:02 PM
You need to use a tripod for macro photography.
03-26-2017 01:05 PM
I don't know if you need a tripod but he is correct in assuming you need to hold the camera still. Your examples show camera motion. In short you were not steady when you pressed the shutter button.
03-26-2017 01:08 PM
This condition is from not enough light resulting in a slow SS. You need to fix the light problem so you can boost the SS. Try a higher ISO, see if that helps. If not additional artificial light will need to be supplied by you.
03-26-2017 02:09 PM - edited 03-26-2017 02:10 PM
You need a tripod, and you need to use Av mode. A remote shutter control, or the shutter delay timer, would help, too.
03-26-2017 08:35 PM
Yeah - that's motion-blur. When hand-holding that particular lens, you probably want a minimum shutter speed of 1/100th sec. Or just use a tripod (or rest the camera on something so it doesn't move.)
