03-01-2014 04:40 PM
I have my camera since 2010. lastweek I tried taking out pictures and realise I wasnt getting a focus but I took a picture. Now today, I am pressing the shutter button but nothing.
I have a stock lense EFS 18-55MM and its on the Canon EOS Rebel T3.
I took the lense out and cleaned the contacts, and replaced the lense, this did not helped. I also did a manual reset on the features but that didnt help either.
Please help me.
09-06-2014 06:50 PM - edited 09-06-2014 06:51 PM
I found these forums searching through Google for the same issue - didn't look like anything listed would help short of sending the camera to Canon for a repair...
Then - I manually exercised the part of the lens that automatically extends/retracts to focus in auto mode (no idea what it's called). Twisted this mechanism in and out about 3 times - and then the camera started working as normal again. Maybe it was just stuck?
Anyway - that's my solution and i'm sticking with it - until of course the camera quits working again and my method doesn't fix it.
09-06-2014 10:07 PM
Hi thanks, will give it a try, I am still stuck at the same problem.
Will give your method a try and let you know what the success was like.
Cheers mate!!!
03-02-2014 09:00 AM
Mike mY AF Point are set on Automatic with allpoint on red.
03-02-2014 07:58 AM
I have attached a photo to illustrate wheni hit on the shutter button do you see under the minus 3 where the comp is located. I cant recall but it suppose to be at 0. I dont know how it got there, I tried changing it but I was unsuccessfully.
Also you can see my batter is fully and the SD card can take alot of pictures as the image illustrate.
