Canon EOS Rebel T1i/500D - Card Write Protected Error
Jacquelinegt90
Hello,
Whenever I turn my camera on it says " CARD WRITE PROTECTED."
I flipped the lock to unlock on the SD card multiple times. When that did not work I replaced it will a new SD card that had never been opened. I tried multiple SD cards at the local store. However this doesn't seem to be the issue.
What is my solution here?
Thank you!
4 REPLIES 4
kvbarkley
Then it is the little lever inside the camera that engages the switch. You can try to use a thin stick or something that will let you work it back and forth.
Is it inside the card slot?
Hi Jacqueline and welcome:
Yes, peer inside with a light and check it out before poking around - a magnifying glass might be useful.
cheers, TREVOR
kvbarkley
Yes. There is a little mechanical switch inside the card slot that engages the write protect switch.
