05-17-2020 01:55 AM
05-17-2020 09:07 AM
Since it on,y happens with the lens attached, I would suspect a problem with the lens. Try another lens to confirm it. The camera and lens are not worth repairing as they are so cheap now.
05-17-2020 09:21 AM
@MikeSowsun wrote:Since it on,y happens with the lens attached, I would suspect a problem with the lens. Try another lens to confirm it. The camera and lens are not worth repairing as they are so cheap now.
I am not familiar with that specific camera, but I had suspected that the lack of a battery would hinder the camera's metering system. I might work if the camera is in full manual mode, which would require the use of a handheld light meter, or at least another digital camera, to read the exposure.
05-17-2020 10:56 AM - edited 05-17-2020 11:01 AM
His battery is not dead. The camera would not work at all if the battery was dead or undercharged.
The blinking battery icon is a form of error message on these EOS film cameras. I have seen this happen with my film cameras when the lens aperture sticks partially closed and does not fully open between shots.
05-17-2020 10:58 AM
"This doesn’t happen at all without the lens attached, so I was wondering if it was a lens or camera issue and what i could do about it."
The battery is likely bad. It doesn't have enough power to run the camera and the lens. So, it seems to work with just the camera and no lens. I have seen these go for $50 bucks so almost any money spent on it is not wise. Even a new battery and/or charger. But than again it's your choice.
