12-09-2022 08:06 PM
I just got my new EOS R6 Mk2 camera body today, bought it directly from the Canon online store, got it from DHL, undamaged box, packaging intact. But then as I take out the camera body I noticed a sound as if there is something loose inside the camera. I kept checking and there is nothing wrong on the outside, but every time I shake it even just a little bit I can hear that very obvious noise.
I called the support line and I was told that "it's normal", "there is nothing wrong with it, it will work just fine", "we know exactly what you're talking about, we have one at the office that makes that noise and it works fine". I told the guy that I didn't feel comfortable getting a new camera that sounds like it is broken, even if it works fine.
Has any of you had this situation? if the camera operates OK, but has this sound as if it was a damaged, refurbished gear, that I paid about full price (not cheap), why should I have to settle for something that is not entirely to my satisfaction? shouldn't I be able to return it and get another one?
What are your thoughts? suggestions on how to handle this?
Thank you in advance,
Art
12-09-2022 09:53 PM - edited 12-09-2022 09:54 PM
Without actually hearing it, I can only guess that it is the in-body image stabilization system (IBIS). Our R5 and R6 have a slight rattle or more of a light knock when shaken, actually just when shifted like from being picked up. They don't do it all the time, just when first picked up. Not sure why not all the time, but that's my experience with them. The R6 mark II may be different.
Newton
12-09-2022 11:58 PM
That's what a friend of mine told me. And I can hear the rattle all the time, just as I pick it up and with any shaking movement. If that is the IBIS indeed, I would assume that is not something that should be loose, would it? otherwise, it would be like that on every single model.
Thanks,
Art
12-10-2022 12:33 AM
oh well, I just found another post in another forum where someone reported the same thing, but when you turn on the camera it doesn't make the noise anymore. I tried it and indeed. So it seems like that is the IBIS thing, a stabilizer that is loose when the camera is off.
12-10-2022 12:52 AM
@artvega wrote:That's what a friend of mine told me. And I can hear the rattle all the time, just as I pick it up and with any shaking movement. If that is the IBIS indeed, I would assume that is not something that should be loose, would it? otherwise, it would be like that on every single model.
Thanks,
Art
Yes, Art, it should be floating around in there, at least that's the way I understand how it works. It's pretty interesting.
Newton
03-10-2023 07:18 AM
Hi, thanks for posting your case. I just received my R6 Mark II and I had the same impression, that something was loose inside. I contacted the store that sold me the camera and they informed me that this noise is due to the IBIS, and that it should go away with the camera on. I turned the camera on, and indeed the noise went away. Therefore, I would say that it's normal and expected. I am keeping mine like it is.
03-10-2023 07:54 AM - edited 03-10-2023 07:55 AM
Yes it'll be the IBIS mechanism when not energised. There's a similar phenomenon with IS lenses - there's a lens group inside that rattles when the IS is not energised. On many lenses you can see the IS group wobbling around when you look into the front of the lens. Once the IS is active, these components, and the IBIS component in your camera body, are held in place by the IS motors, which then move them tiny amounts to effect the stabilisation. It's an amazing system and very effective, but rather disconcerting when you first encounter it powered down and it rattles!
03-21-2024 05:06 PM
I bought the same camera and right away was getting error messages so I returned to Canon Service and they replace the main circuit board. When I got the camera back I noticed that same noise and am certain it wasn't there before. It's back at the service center and they are saying its the IBIS moving and that will stop once the camera is turned on. The only thing I am certain of is that noise wasn't there before. I handled the camera frequently when it was turned off and not once did I hear that sound.
