Canon EOS 80D camera's popup doesn't closed after an error
sai4an
I was taking some photos in manual mode and all of sudden it went into burst mode and it took some snaps and then camera's flash popped up with an error which vanishes in seconds. And after that the flash wasn't closing anymore. I googled it but I didin't got any leads. I tried to switch on/ off and removed the battery in the process. But still the flash wasn't closing at all.
I am using EOS 80D.
Thank you in advance.
1 REPLY 1
deebatman316
I would recommend resetting the camera back to factory. To see if the problem goes away.
-Demetrius
Current Gear: 5D Mark IV, EF 16-35mm F/2.8L III USM, EF 24-70mm F/2.8L II USM, EF 50 F/1.8 STM, EF 85mm F/1.8 USM, EF 70-200mm F/2.8L IS III USM, 430EX III-RT, 470EX-AI & 600EX II-RT
Retired Gear: EOS 40D, Sigma 17-50mm F/2.8 EX DC OS HSM & EF 28-135mm F/3.5-5.6 IS USM
-Demetrius
Bodies: EOS 5D Mark IV
Lenses: EF F/2.8 Holy Trinity
