06-13-2023 09:39 AM
Hi There,
I have a 10year old Canon EOS 700D camera that has been looked after. In low light the flash pops up but the flash will not go off. Any ideas before I look at getting it repaired as I am not sure how long the life is of an electronic camera. Bulb blown??? Thanks
06-13-2023 09:49 AM - edited 06-13-2023 10:18 AM
What mode is the camera set to. In some modes the AF Assist Beam can be turned off. Will the flash fire for the actual picture though. If you're in the Creative Zone (M, Av, TV & P) modes. The AF Assist Beam will NOT fire. If the AF mode is set to AI Servo. The AF Assist Beam ONLY works with One Shot & AI Focus. One Shot and AI Focus has focus lock. AI Servo doesn't have lock so the AF Assist Beam won't fire.
06-13-2023 10:05 AM - edited 06-13-2023 10:07 AM
I'd try a settings reset, then determine of the flash is faulty.
If it is faulty, then use this as a guideline. A used 700D (T5i) costs about $235.
Repair Option: midwestcamera dot com
If the repair will exceed this price point, its time for a new camera.
If you'd like help or recommendations, let us know.
10-12-2024 06:20 AM
FYI, I just had a 700D with exactly the same issue. Fortunately I did have another faulty 700D and could swap parts, I tried swapping the top including the flash and the issue remained. I then swapped just the DC power board and it fixed the issue. So it was a fault with the flash circuit on the DC power board.
