08-07-2023 06:12 PM
During a shoot a week ago, my 90D shut down. I checked/changed the battery, and checked the SD card inside, with no change. I removed the SD card and the camera turned on without an issue. I’ve since tried a few different cards, with no change in function. Tried cleaning the insert compartment, not sure what else there is to do at this point?
08-07-2023 06:41 PM
Can you look into the memory card slot to see if any of the pins are bent? I suspect there is a short in the camera when a card is inserted.
May need to contact Canon support to schedule a repair.
08-07-2023 06:42 PM
Also, double-checking here, but are you using full-sized SD cards? Micro-sized cards with adapters can be problematic.
08-16-2023 10:37 AM
Checked in the slot, didn’t see any bent pins or dirt. Also tried both standard sd card and a micro with an adapter, no change. Thanks for the suggestions though!
08-16-2023 09:52 PM - edited 08-16-2023 09:53 PM
@Jnosbisch wrote:Checked in the slot, didn’t see any bent pins or dirt. Also tried both standard sd card and a micro with an adapter, no change. Thanks for the suggestions though!
The micro-SD cards are [NOT] recommended for use in the camera. The adapters tend to fail and cause the camera to malfunction.
But, you are reporting that your camera shuts off when you insert an SD card into the slot and close the door. Let’s try a quick, unscientific test of the card slot electronics.
What happens if you insert an empty micro-SD card adapter without a memory card inside of it? Let’s see if this result points to an electronic problem or a mechanical issue of some kind.
