05-17-2021 11:46 AM
I have Sigma 150-600 OS Contemporary lens and Canon 90D body.
While working in this combination, after some time camera shuts down its LCD panel and i can't return it working by pressing shutter button. i hear lens motor but nothing happen,
If i shut down and power on the camera, it returns to work and i can make pictures again.
I do not see such effect while working with other lenses: Canon 24-105 F4, 70-200 F4 and Tokina 11-16.
Battery is fully charged.
Camera FW version 1.0.0
Lens FW 2.3 (latest)
05-17-2021 12:08 PM
Do you have the sigma dock? There may be a firmware update for the camera.
How new are your batteries? If they are old, the sigma may be drawing too much power.
05-17-2021 12:44 PM
Yes, i have Sigma dock. FW is the latest.
Camera FW is not latest: my - 1.0.0, latest 1.1.1, but i didn't see this correction in FW release notes
The batteries:
- one from 2010 (from my old 60D), another from 2019 (original from 90D package)
Both are fully charged, no difference.
05-17-2021 01:03 PM
"Camera FW is not latest: my - 1.0.0, latest 1.1.1, but i didn't see this correction in FW release notes"
Updating the 90D FW will not help or correct this. Canon does not update FW to make third party lenses work on their cameras. I dount it is your batteries either but a ten+ year old battery probably needs some thought to be replaced soon.
05-17-2021 01:07 PM
"... camera shuts down its LCD panel and i can't return it working ..."
Does this mean if you use the view finder instead of the LCD it works as expected? No shutdown? A further examination of exactly how you are using your gear is required. Plus the environmental conditions.
05-17-2021 04:18 PM
I use the same combination regularly without any issues, so I suspect it is a fault in either of the individual units rather than a compatiblity issue.
Does this occur with any other lens?
05-18-2021 01:30 AM
Tronhard,
thank you for comment.
Probably it is the case. I didn't see such issue before.
Will call local Canon represntative and ask.
Anatoly
05-18-2021 05:42 AM
@anatolyf wrote:Tronhard,
Anatoly
If you have not seen the issue with this body before you used the lens, I would suspect the lens as it is the obvious variable. Still, it doesn't hurt to ask, but be aware that having Canon check the body may cost you...
05-18-2021 01:27 AM
i use viewfinder only. Display is off.
