04-28-2024 06:01 AM
I have tried to update the firmware of the Canon 77D dlsr, from ver 1.0.2 to 1.1.0.
The first time I did it - it was stuck in the 99th percentage of the process.
The only option available to see in the camera (after removing and installing back the battery) is the Firmware Update program.
I then used other cards, formating the cards both using other similar Canon DSLR (not the exact model - Rebel T5i) and trying to both update to 1.1.0 or 1.0.3, each time the result is the same (I have once managed to get to 100% but it was stuck there..)
Any help will be appreciated!!
-- Nissim
10-29-2024 01:09 PM
Did you now formatted the card again and put the right canon version again? Are you sure that now you are using the right canon firmware and a right sd card type?
10-29-2024 03:17 PM
when i dump it will be files like rom and rom1 md5 after that i need just to delete the dumper.fir and put the update fir after that i just put the sd card back to camera and update ?
10-29-2024 03:49 PM
Yes, delete all the files except of the update fir and try to do the upgrade again. Now it should work given that you see 0.0.0 -> 1.0.3
10-30-2024 05:16 AM
i will try again by
format the card then put the fir dumper
insert to camera the run it after that format the card and put for first time the update fir thats it?
okay it shows 0.0.0 to 1.0.3 but it stucks at 99%
i think it needs new board 😓
