09-27-2022 05:25 AM
Hi. Please need some assistance. I have a canon 750d that does not switch on when i insert the sd card inside the camera. Once i eject the sd card and switch on the camera it switches on and i can do functions as usual but once i put in an sd card no powering up. Is the sd card slot damaged? Thanks in advance.
09-27-2022 06:16 AM
Sorry to hear you are having issues. When did this problem begin?
What type of SD card are you using? Brand? Storage capacity? Is it a full size card?
09-27-2022 06:51 AM
Thanks for the reply. I have a 128gb, c10 , xc I and a 64gb c10 xc I. I have tried it on another 750d camera they work. The camera i now have connected to the pc via the software and i can shoot n take pictures straight to the pc. As soon as i try camera to pc with card inside still no power.
09-27-2022 07:24 AM - edited 09-27-2022 07:25 AM
Definitely sounds like an issue associated with the SD card or card slot.
Are you using full size SD cards? What brand? Can you post a photo of one?
09-27-2022 08:27 AM
Since the cards work in a different camera I would focus attention on the card slot.
Look into the slot with a flashlight and see if you see any foreign material or any bent pins.
09-27-2022 09:03 AM
I would suggest that OP try a 32 GB or smaller. Older Canon cameras cannot use 32 GB or larger cards.
-Demetrius
40D, 5D IV, EF 16-35mm F/2.8L III, EF 24-70mm F/2.8L II, EF 28-135mm F/3.5-5.6 IS USM, EF 50 F/1.8 STM
430EX III-RT & 600EX II-RT
09-27-2022 09:09 AM
From the camera manual:
09-27-2022 09:35 AM
I know that older cameras often cannot use or format. 64 GB or larger cards so I that maybe one cause.
-Demetrius
09-27-2022 10:42 AM
I agree. The older Rebels seem to choke on SDXC cards. I know what the manual says.
09-27-2022 11:38 AM
My wife has a T6s (an upscale version of the T6i/750D). Works fine with a 128 MB SDXC card.
