05-14-2019 05:33 PM
Hi all, i'm out in madagascar on a photography trip, and my main body, a very lightly used 6d mkII's screen has stopped responding, no response when i hit the menu, liveview etc, nothing, but weirdly it does perform completely normally when i switch it off and on, with the "sensor cleaning" message, also "no card in camera" message, but apart from that nothing. It's extremely frustrating as i am unable to change any menu settings, or operate live view, or even look at my pics after shooting, but again, strangely i get the fraction of a second brief dispaly of my shot after i shoot, The camera has been like this now for some weeks, and i'm still using it, despite its current limited functionality. Any advice or assistance will be greatly appreciated,
Best Regards
05-14-2019 05:36 PM
Hit the info button a few times or make sure that the eyepiece is set properly.
05-14-2019 05:40 PM
05-14-2019 07:56 PM
Not sure about the 6D, but some cameras have a sensor at the eyepiece that turns of the LCD when it is blocked (i.e. when you put your eye to the viewfinder.) A mispositioned eyecup can block the sensor.
05-15-2019 09:41 AM
Might also try resetting the camera (if possible), with the lens and card removed. I know you said you are not able to see the screen in some cases so this migjt not be possible.
05-15-2019 10:53 AM
Thanks for the response, but i have no idea how i could reset when i cannot access any of the menus, also, even if i could reset, and it did'nt, solve the issue, i would then have a camera without current firmware, and i'd have lost my settings in regards to image quality, like raw for example, so that's a major concern, as i would not be able to get back into the menu system, and select raw.
05-16-2019 09:02 AM - edited 05-16-2019 09:03 AM
You've crossed the line into "time to contact Canon" for service territory. You'll have to limp through the rest of your trip, come home and get the body serviced.
