12-19-2015 08:45 PM
Is this shutter failure? Camera is only a year and a half old? What is the best thing to do? Return it to Canon or fix locally as it is no longer under warranty! What kind of warranty does Canon give for it's repairs? Thanks:)
12-21-2015 09:44 AM
The only choice you have is to get a hold of Canon Service. Nobody will beat their repair work.
I will guess you didn't do anything like drop it or got or wet? Stick your fingers inside the mirror box or foreign objects? No q-tips?
12-19-2015 11:00 PM
It's difficult to see the image but I think I see a shutter blade hanging down in a way that it should not be.
The typical shutter life of a 6D body is believed to be around 100,000 actuations. But in order for this to be an average, as many camera bodies have to exceed this by the same amount that some camera bodies come up short.
You should still contact Canon service because it's far cheaper to have the shutter replaced then to get a new camera.
12-21-2015 09:44 AM
12-21-2015 05:05 PM - edited 12-21-2015 05:09 PM
@Pamela4565 wrote:Is this shutter failure? Camera is only a year and a half old? What is the best thing to do? Return it to Canon or fix locally as it is no longer under warranty! What kind of warranty does Canon give for it's repairs? Thanks:)
One of the ways that accelerates shutter failures is using the camera outside of its specified temperature range.
For the 6D the Working Temperature Range is 32-104°F/0-40°C
This was a problem reported last winter by a few users with the 70D since it was exceptionally cold and their were many inexperienced users. People were leaving their cameras in their cars outside overnight and then trying to use them causing shutter failures.
While many people get away with using their cameras at subzero (C) temperatures they do so at their own risk. Also precautions like keeping the camera on so the electronics generates some internal heat can help.
12-21-2015 05:29 PM
I live in Baja and never leave my camera in the car..cold would not be an issue;) but thanks
12-21-2015 05:33 PM
Yes, thanks. I will be taking it in for repair.
12-21-2015 05:35 PM
no..happened while I was shooting hummingbirds-I do a lot of shots to get one...Dissapointed though as I have nowhere near 100.000 shots:( maybe 5000-6000 a montha nd I've had the camera for a bit over a year. Out of waaranty as is usually the case..
12-21-2015 06:07 PM
Pamela,
If you were to shoot 60K a month for a year, that is 72, 000 shots. A little over a year and you are rubbing up to the 100K figure. I actuall don't think that figure is accurate, however. I think that was a ballpark guess. I would put the number closer to 150K but that is neither here nor there as it did fail.
I also don't think it is a true average. In other words I don't think one camera had to fail at 1 click and another one at 200, 000 to get an average before failure of 100, 000 clicks. The number is an "expected" figure as most of the 6D's go there routinely (150K) and some (most) go well over their rated life.
How about sharing a few 'hummers'? I love to photograph them too. I am currently using my 1D Mk IV and Sigma 150-600mm f/5-6.3 DG OS HSM Sports Lens for Canon on a Manfrotto 3046.
Although not a hummer, I shot this girl today with it.
12-21-2015 06:23 PM
Thanks for the input-Beautiful shot there.Love Cardinals.Funny, my old Rebel4Ti has many more shots than the 6D and is still going strong..hope I didn't just jinx myself;) I'll be using it until I get the Canon6D sent out for repair. I live in Baja so these things can be challenging!
12-22-2015 09:12 AM
Oh, my, very nice.
"I live in Baja so these things can be challenging!"
They can be 'challenging' in Kansas, too! Don't worry about the number of shots. Just use your camera'as you see fit. As I said most camera's exceed that estimate easily. It is not a, "I hit my number and I am done.", thing.
