07-14-2025 10:17 PM
Good evening,
I recently discovered that my Canon 6D Mark I doesn't turn on. I charged my battery fully, there was an SD card inside and still it would not turn on. I bought new batteries, charged them and still, nothing. I took the camera to a camera repair shop and the tech said it appeared that the batter door switch/trigger was broken and not completing the circuit to turn the camera on once the door was shut. Now, he found a switch on ebay for about $10, and it look like a single switch that one would solder on to a chip board. However, when I got home and attempted to find the same switch, I noticed that it seems as though the Mark I's battery door switch/trigger is actually on a ribbon and not just a single switch soldered to a board. Can anyone tell me the correct part I need to find to get this camera, hopefully, fixed. Is it on a ribbon or is it a single switch that's soldered? Thank you!
07-16-2025 05:41 PM
Greetings jburge,
I am sorry to hear that your EOS 6D camera is not powering on due to it having hardware issues. You may try reaching out to our Parts Department for information on the part you need, the cost, and assist you with ordering the part if available. they can be reached at 1-866-481-2569 from Monday through Friday between 9:00 am – 6:00 pm ET.
