10-16-2015 07:21 AM - edited 10-16-2015 08:49 AM
Canon 6D
24 - 105mm f/4L IS USM
Raw
All of my photos are coming out dark and underexposed. I'm using the light meter inside the view finder after pressing the shutter button half way. It'a always to the left in the negative. I adjust to Zero but the settings seem ridiculous.
Is my camera damaged? I just bought it three weeks ago so perhaps something is wrong with my body.
I'm getting better images when using Creative Auto than in Manual with same settings.
My T5I is getting better images than the new 6D.
Something feels wrong
10-16-2015 08:57 AM
We'll need a better explanation of how you are shooting. Mode, conditions etc.
10-16-2015 09:37 AM
Agree on needing more info. Can you post a shot with EXIF data so we can see the settings?
Try resetting all camera function to factory default. Its a menu option.
10-16-2015 12:08 PM
For what reason are you shooting Manual? Do you use Tv and Av mode and if so do they work? It seems unusual to exclusively use 2 settings as different as full Manual and then Creative Auto.
10-18-2015 04:15 PM
I always shoot manual with my 6D too and have found it takes some getting used to to get the exposure right under certain conditions. I have heard the same thing from other 6D owners as well.
You mention the meter is to the left so you adjust it to center and the "settings seem ridiculous". What does that mean? Are you using center point focus or all?
10-19-2015 12:09 PM
"I'm getting better images when using Creative Auto than in Manual with same settings.
Something feels wrong"
It is! You don't have the proper exposure set. Also make sure you didn't dial in any exposure comp. Reset the camera to factory defaults and go at it again. Remember you must set the aperture, shutter and ISO and have exposure comp set to 0.
This is manual mode.
BTW, the focus points have nothing to do with this.
10-19-2015 05:34 PM
Duh! Of course they don't. I was thinking center weighted or evaluative.........no idea why I wrote focus points.
10-19-2015 05:49 PM
When you shoot using Manual mode the camera will meter using it's internal "reflected" light meter and it will offer advice on the exposure but it will not change exposure settings for you.
This means that, depending on your metering mode and subject, you'll point the camera at the subject, half-press the shutter, and take a meter reading. The scale at the bottom of the viewfinder window. It is marked with a -3..2..1..0..1..2..3+ with a "-" side and "+" side. There's an arrow indicating what the camera thinks of your exposure. For example if the arrow is under the "-1" side, then it means the meter believes you are underexposed by 1 stop. You can either adjust the aperture, or the shutter speed, or the ISO until the meter is indicating the "0" position ... that's where the camera thinks you'll need to be to get a correct exposure.
But these meters are just tools and they can be fooled (and it's not a defect.)
In "Evaluative" mode, the camera analyzes the the light in several "zones" all around the frame and tries to indentify the best exposure based on those zones.
In "Center weighted" it works exactly as "Evaluative" (all zones are metered) but it gives much stronger "weight" to the meter readings from the zones near the center of the frame and much less weight to the zones outside the center area.
In "Spot" metering mode the camera meters only in an area near the center AF point (it does not follow your selected focus point ... it uses the center point regardless of your selection.) No other points are considered. This means if your camera was in "spot" mode and you metered a bright object at the center of the frame, the camera would like underexpose your shot because the bright object makes the camera believe it needs to reduce light intake and since the camera isn't allowed to factor in any other zone, the camera will not realize that the images is underexposed in other zones.
Bright or mostly "white" subjects will fool a reflected light meter into underexposing the shot. This is because the meter is designed to anticipate an average level of reflectivity (I think it's about 12% for your camera) but some objects will reflect considerably more light back to the camera's light meter than other objects (white reflects quite a bit... black doesn't reflect much). The camera doesn't "know" what it's metering... it only knows how much light is being reflected back.
In situations where you really want more accurate exposure, you would visually look for the brightest area in your composed frame and also the darkest area in your composed frame and you would use "spot" metering to manual meter both points... and then use the exposure halfway between those two metered points (there are hand-held light meters that do this automatically.) A portrait photographer using a hand-held "incident" light meter doesn't just meter the subject's face... they meter the "shadow" side of the face and the "highlight" side of the face and use both readings to find an exposure that captures the range needed.
10-19-2015 10:31 PM - edited 10-19-2015 10:37 PM
Meaning my ISO is at 400 or above no matter what and it's driving me crazy. I should be able to shoot some things at 100 but it's always dark. The only way the light meter stays in the center with 100 ISO is if I bring my Shutter down to 30 or 40. I'm trying to shoot animals and I need my shutter at like 200 or above. I'm hating this camera.
10-19-2015 10:32 PM
I was not using center focus. I was using Multi point.
