11-12-2022 06:53 AM
Hi
i am frustrated by the delay between shots while shooting wildlife from a hide on live view. With or without remote shutter release the screen goes black for several seconds before one can release shutter again. I hear this is a fault with the canon dale’s but was wondering if if would be solved with a super-fast CF card as the camera seems to be slow to process the photos from live view. My card is a recognised brand 160mb/s.
11-12-2022 10:31 AM - edited 11-12-2022 10:35 AM
Make certain that you do not have Mirror Lockup enabled. Also, check your Shutter Mode. Having the delay timer enabled may cause a similar behavior [during Live View].
If you were experiencing a memory card issue, then you should see the red LED light up and flicker during the delay. In fact, the camera might even display “BUSY”, while it writes to the card.
If you are shooting RAW, then disable all in-camera image correction and noise reduction settings.
11-15-2022 04:43 AM - edited 11-15-2022 11:50 PM
@Leenorman wrote: Portal4meHi
I'm currently experiencing the exact same thing.
