08-21-2020 10:06 AM
Hey everyone,
I'm attempting to troubleshoot an issue I'm having with flash and a remote trigger. I'm using the Canon 5D Mark IV.
While in live view, I am able to take a photo, but the flash will not trigger when taking a photo. If I switch live view off, the flash will trigger. Why is this? Is there a way to override this?
When I'm not in live view, and autofocus is enabled on my lens, my remote trigger is inconsistent. Sometimes it will take the shot, but other times it will simply autofocus, and won't take the shot. I can see it getting signal on the back of the camera, but don't know why it isn't firing.
If I switch my lens to manual focus, the trigger will fire the flash and take the photo every time. Any idea what might be causing this?
My flash is controlled by RF via a hot shoe mount, and the remote trigger is connected via the remote terminal port.
Any help is appreciated. Thank you!
08-23-2020 01:02 AM
Hi SolomonShawn,
Thanks for checking in with us!
There could be a couple of factors at work, so it would help to have some additional information.
05-19-2021 11:01 PM
I'm having a similar problem with my 5D Mk4.
I'm shooting remote with and iPhone 8 running the Canon app over WiFi. Live view. Manual mode. 100-400mm Zoom Canon L lens on manual focus. The flash works with a Canon Speedlite 580. But it doesn't fire with a KuangRen KX-800 macro twin lite. The KX-800 has only one contact pin on its hot shoe. It works fine in view-finder mode, but not in Live view. Same thing without the iPhone and just using the shutter release.
05-20-2021 01:03 AM - edited 05-20-2021 01:04 AM
@RobCPhoto wrote:I'm having a similar problem with my 5D Mk4.
Flash photography is [NOT] compatible with Live View. The issue is that you cannot see what the final exposure would look like prior to firing the shutter. The exposure isn't "correct" until the flash fires, so all you see is a mostly dark screen.
05-20-2021 01:09 AM
Then why does it work in Live View with a Canon Speedlite? Both the Speedlite and the 5D Mk4 are in manual mode.
05-20-2021 01:14 AM - edited 05-20-2021 01:15 AM
@RobCPhoto wrote:Then why does it work in Live View with a Canon Speedlite? Both the Speedlite and the 5D Mk4 are in manual mode.
Oh, your issue is different from the original proble. Probably should have started your own thread.
Why doesn''t your setup work with a third party unit? I don't know. I suggest that you ask the third party manufacturer why isn't their gear fully compatible with Canon gear. Your best course of action is to stick to Canon Speedlights.
07-17-2023 04:23 PM
Thats not at all helpful, thanks for the input.
Theres a setting in the menus for live view, turn off silent shutter. "Silent LV Shoot" Setting one, two or Disable. Disable it and your trigger will sync your flash. Its a shutter speed sync issue.
07-18-2023 12:25 PM
I have a Godox Macro flash that does not fire in Live View mode on my Canon DSLRs. Finally discovered that this is not a "problem" with the flash or the camera. Canon states this in their camera manuals. Third-party flashes are not supported in Live View mode, UNLESS you disable "Silent Shooting". Look up Silent Shooting in your camera manual.
08-19-2024 11:59 AM
That fixed it!
I was going crazy! The flash was firing under my custom Manual settings, but the AF wasn't (with Canon Connect), since I re-assigned the AF button to something else. Then I switched to C1 just to get the default buttons/settings back and it fixed the AF issue but then the flash stopped working! Disabling "Silent LV Shoot" did the trick! Thanks so very much!
08-19-2024 12:46 PM
In live view the first curtain is already open, and that is the one that would be used to trigger the flash to fire. With a Canon Speedlite the camera recognises it and switches the Silent LV shoot to disable. This has two effects, first it means that the first curtain returns to its original position - making the screen go dark briefly and then moves to uncover the sensor and trigger the Speedlite.
