01-21-2014 09:14 PM
Can use a tripod while using a Canon Hand Strap E2 with my Canon 5D mark III?
Or I must remove it when using a tripod?
Thanks.
01-22-2014 10:16 AM - edited 01-22-2014 10:20 AM
I use the older E1, which may be discontinued but is still available. The E2 may interfere with a flash bracket.
I have not tried it. I doubt it will have much affect on a Manfrotto quick release tripod.
01-22-2014 10:17 AM
Thanks.
I guess a strap like this in meant for handheld work, primarely!?
01-22-2014 10:19 AM
What I would be more concerned about is how far from your hand the E2 attaches. SInce it attaches to the tripod mounting hole and not the much closer bolster. (Not on some models)
01-22-2014 10:21 AM
5D Mark III without battery grip or any other acessory.
01-22-2014 10:25 AM
Well you have two choices, get the E2 or buy a battery grip and get the E1. I prefer the latter. Although much more costly, it does offer other worth while benefits.
01-22-2014 10:31 AM
Thanks for the sugestion. I´m aware of the benefits of a battery grip but for now I need to keep it as simple and lightweight as possible. The E2 is the right choice.
I just want an extra support for handheld work without the awful neck strap that hurts my bones. If it works with a tripod, thats a bonus.
For macro works (my other type of work) with tripod, tripod head, focus rail, etc; I don´t use any strap.
01-22-2014 02:24 PM
Which tripod head do you use? Does it have a quick release plate?
Another option for you is to use a quick release plate that includes a strap mount. That way you could use the E1 without a grip. You could also use the E2 strap because the tripod mount screw can be removed from the hand strap.
"Camdapter" makes a bunch of products that may help you: Camdapter
01-26-2014 04:58 PM
I´m currently between tripod heads.
Thank you for the link. Seems good stuff.
